This is the Readme as of May 24, 2018
Basic board bring up, CAN 500 working, LCD working, Buttons (polling) Working, UART1 Serial Working, USB/USB Detect working. Partial REV ENG of schematics,
CPU:STM32F103RB
CAN IC:TJA1050
K-Line : Transistor/Opamp
### Still TODO:
- [o] Add more CAN OBD logic,
- [x] remap SWD to GPIO for CAN chip mute control
- [x] rev eng K-line etc (Prob similar to ELM327 schematics)
- [o] Add protocols for :-
- [ ] 1 SAE J1850 PWM (41.6 kbaud)
- [ ] 2 SAE J1850 VPW (10.4 kbaud)
- [o] 3 ISO 9141-2 (5 baud init, 10.4 kbaud)
- [o] 4 ISO 14230-4 KWP (5 baud init, 10.4 kbaud)
- [o] 5 ISO 14230-4 KWP (fast init, 10.4 kbaud)
- [o] 6 ISO 15765-4 CAN (11 bit ID, 500 kbaud)
- [ ] 7 ISO 15765-4 CAN (29 bit ID, 500 kbaud)
- [o] 8 ISO 15765-4 CAN (11 bit ID, 250 kbaud) - used mainly on utility vehicles and Volvo
- [ ] 9 ISO 15765-4 CAN (29 bit ID, 250 kbaud) - used mainly on utility vehicles and Volvo
- [x] EEPROM not working, SPI still needs work :- FIXED
x = working but not necessarily feature rich
o = implemented but not necessarily working correctly
Device URL :- http://www.autophix.com/en/obd-mate/om127.html
Requires modified Arduino STM32F1x see [this](http://www.stm32duino.com/viewtopic.php?t=72)
also see:
`rogerclarkmelbourne/Arduino_STM32@master...coddingtonbear:HardwareCAN`
also [SPI flash lib](http://www.stm32duino.com/viewtopic.php?t=9)
Device [URL](http://www.autophix.com/en/obd-mate/om127.html)
`PA13` is shared with CAN Mute & SWD, lift leg and leave floating for CANBUS `TX Enable` or add a jumper wire from solder point next to `R18` to `PIN8` of the **TJA1050** SO8 chip, leg must be lifted from pad to allow control (`PA13 `is always *high* when remapped for SWD)
Will be adding K-Line soon
darkspr1te
