Firtst Attempt
A project log for 3 Blink Modification for SAAB 9-5
Activates the blinkers 3 times from just a touch on the indicator stalk for 1999 SAAB 9-5
saabmanSaabman 05/29/2018 at 12:300 Comments
After the blinker has been held on for while when it turns off if there is a bit of contact bounce it will latch the blinker for 3 seconds. its not a show stopper but Id like to rectify it. In reality it may rarely occur as the blinker switch contacts are a bit more robust than my dodgey piece of wire. Ive been playing around with some techniques to debounce it but nothing is really working out.
It may be that I rewrite without using interrupts and poll the input but ill leave it like it is at the moment if you want to have a play here is what I have so far.
/* Implementation of 3 second "auto" blinkers for SAAB9-5 by SAABAus Sept 2017
 * uses pins 2 and 3 as inputs untill required than change to outputs to hold the blinker on.
int Blink_left = 2;                     //  Left Blinker switch on pin 2
int Blink_right = 3;                    //  Right Blinker Switch on Pin 3
int debounceTime = 200;                 //  debounce lock out time
bool Blink_left_status = 0;             //  Store for the current status of the Left blinker
bool Blink_right_status = 0;            //  Store for the Current Status of the Right Blinker
unsigned long debounce = 0;             //
unsigned long trigger = 0;
unsigned long Time_start = 0;
unsigned long OnTime = 3000;             // Time blinkers stay on for in ms
void Right_Blink ()
  if (millis()- debounce > debounceTime)
  if (Blink_left_status == 1)           //check to see if the left blinker is on
    Blink_left_status = 0;             // if it is turn it off
    digitalWrite(Blink_left, LOW);
    pinMode (Blink_left, INPUT);
   else
    Blink_right_status = 1;             // if the left blinker wasnt on turn on the right blinker
    pinMode (Blink_right, OUTPUT);      // set the right pin to an output
    digitalWrite (Blink_right, HIGH);   // turn on the right blinker
    Time_start = millis();              // Starts the 3 second timer
   debounce = millis();
void Left_Blink ()
  if (millis() - debounce > debounceTime)
      if (Blink_right_status == 1)           //check to see if the right blinker is on
       Blink_right_status = 0;             // if it is turn it off
       digitalWrite(Blink_right, LOW);
       pinMode(Blink_right, INPUT);
      else
        Blink_left_status = 1;             // if the right blinker wasnt on turn on the left blinker
        pinMode (Blink_left, OUTPUT);      // set the left pin to an output
        digitalWrite (Blink_left, HIGH);   // turn on the left blinker
void Blinker_reset()                      // checks to see which blinker is on and turns it off
   if (Blink_right_status != 0)
    Blink_right_status = 0;              // Sets status to off
    digitalWrite (Blink_right, LOW);     // Turns off blinker
    pinMode (Blink_right, INPUT);        // Returns to listening to blinker switch
  if (Blink_left_status !=0)
    Blink_left_status = 0;              // Sets status to off
    digitalWrite (Blink_left, LOW);     // Turns off blinker
    pinMode (Blink_left, INPUT);        // Returns to listening to blinker switch
void setup() {
  // put your setup code here, to run once:
pinMode (13, OUTPUT);
attachInterrupt (digitalPinToInterrupt (Blink_left), Left_Blink, RISING); //when the left blinker switch goes high call the left blinker ISR
attachInterrupt (digitalPinToInterrupt (Blink_right), Right_Blink, RISING); //when the right blinker switch goes high call the right blinker ISR
void loop()
    if (Blink_left_status == 1)           //this little section is for working out how to deal with the bouncing switch on release after the blinker has been on for a while
    digitalWrite(13, HIGH);               // built in LED dipsplays the what the arduino thinks is the status the left hand blinker
    else
      digitalWrite(13, LOW);
  if (millis() > (Time_start + OnTime)) { // if more than the alloted time has elapsed check to to see which blinke ris on and turn it off
      Blinker_reset();
