Programming connector
A project log for konijntje-thermo-humi
Gadget that shows room temperature & humidity on a LED-bar
christoph-tackChristoph Tack 05/31/2018 at 20:080 Comments
Choice
There was a need for a programming connection to the devices.  The REDFIT IDC SKEDD has been chosen to that purpose.
Alternatives are : using push pogo-pins (which need some custom fixture), or using edge mounted DB9-connectors, which don't provide reliable connections.
Mounting to the IDC
To mount the SKEDD to the IDC, special tooling is "needed".  A cheaper way of mounting these connectors goes as follows:
Mounted SKEDD
AVRISP MkII with mounted SKEDD connector
