Solar powered heat engine
A heat engine that uses the expansion of air in a PET bottle (heated by sunlight) to push water through a plastic tube.
0 comments
0 followers
likes
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This project is about trying to make a heat engine that uses solar heating to heat air inside a PET bottle. As the air expands, it pushes water through a plastic tube to change the centre of gravity of the mechanism.
