Graphics formats
A project log for Ultimate retrocomputer
Collecting ideas for building a computer to be the best an early 80s 8-bit home computer could have been.
julianJulian 08/11/2018 at 16:101 Comment
Due to constraints of what can be done with the hardware I'm planning to use, my display is pretty much required to be either 640x480 or 720x576 (or 320x240/360x288, the latter formats produced by doubling pixels).  But what format should I store the pixels in in memory?
Historically, there have been a lot of options:
I was originally thinking of allowing modes up to 16-colours, but the memory bandwidth requirements for that are quite high (to process 320 pixels would require 160 bytes to be read for each line; a VGA scan line last 32us, or 64us if we can use a buffer to produce a single line and output it twice).  I'd still like to support it, but suspect it may only really be useful for showing small areas (perhaps as a format for sprites, or for small inset areas of the display).  But that's OK -- my plan for the display hardware supports using different formats for different parts of the screen (inspired by Atari's ANTIC, but improving on it so that we can partition sections horizontally as well as vertically).
But: is there a stopgap between pure 4-colour and 16-colour that could be useful to support?  8-colour is interesting, but 3 bits per pixel makes it hard to work with -- the hardware would need to handle 8 different variations of where to pull pixels out, and only multiples of 8 pixel widths work without wasting memory.  Planar arrangements are possible, but require the hardware to fetch memory from much more random locations, which is less efficient.
But there other possibilities.  What about, for example, using a 2-byte record with a selection of palette entries combined with a very small bitmap using those palette entries?  Something like this:
|15|14|13|12|11|10| 9| 8| 7| 6| 5| 4| 3| 2| 1| 0|
|COLOUR 0|COLOUR 1|C2 HI|PIX 4|PIX 3|PIX 2|PIX 1|
This arrangement has a few interesting optimizations:
The fact that one of the pixels is implicitly coloured makes it difficult (but not impossible) to update this on-the-fly, but that's OK -- I envisage this mostly being used for static images (e.g. backgrounds, or even sprites) with dynamically generated content using another format... perhaps this one:
|COLOUR 0|COLOUR 1|P9|P8|P7|P6|P5|P4|P3|P2|P1|P0|
Here we have two pallet selections applying in the obvious fashion to 10 pixels, which makes updating the pixels quite simple, and allows a reasonable amount of flexibility.
What other formats could be useful?  I'd love to hear any suggestions.
roelh wrote 12/13/2018 at 22:24 point
Hi Julian,
Currently I also am working on ideas for a video unit. The aim is to connect it to the https://hackaday.io/project/161251-1-square-inch-ttl-cpu. The goal may be partly the same as yours:
- minimal number of components
- Quarter VGA 320x240 graphic resolution (80 nS pixel time). With 55nS RAM, this should be possible. each line is repeated two times, with 8 bits per pixel, need less than 128kByte memory.
- Text mode 640x480, so at least 80 characters per line
- No specific character ROM or palette memory
- Free mixing of graphics and text mode.
My design has following system:
- Every 80nS, one byte is delivered to the video system. Each line info is repeated two times.
- If bit 7=0, this is a control byte. Bit 6 in the control byte determines if following bytes with bit7=1 are either:
     - A 7-bit colorbyte, or
    - A 7-bit text byte.
For graphics mode, after selecting color mode, the color pixels simply follow.
Text bytes are send to a shift register, that shifts with double frequency (40 nS). This gives double horizontal resolution for text. The text bits switch the output between selected color or a "fixed" textcolor. So a byte represents a single line of character pixels.
Problem is, that the next line has the same information bytes, but the text must be different. Solution is, to alternate text bytes for odd and even lines. This will have the result that the alignment differs by 80nS between two lines. Therefore, the 5 character bits will be alternated between left and right alignment within the 7 available text bits, as follows:
- - x x x x x       odd line
    x x x x x - -   even line
Nice thing is, that text mode integrates good with graphics mode.
The control byte will also have some other bits:
- H and V synchronization
- Linecounter reset
- the (previously "fixed") text color (3 bits seem enough)
What do you think ?
best regards,
Roelh
