SW6_BOM_R1.csvBill of materials for the superwide SW6.ms-excel - 1.28 kB - 11/28/2020 at 03:54 |
sw6_main_r1.zipKiCAD files for the superwide SW6. Also contains PDF files of the board schematic and PCB layout.x-zip-compressed - 353.27 kB - 11/28/2020 at 03:54 |
SW6 lens ring v2.stl3D file of the lens adapter for the superwide SW6.Standard Tesselated Geometry - 134.07 kB - 11/28/2020 at 03:53 |
SW6 monocle v2.stl3D file for the lens monocle for the superwide SW6.Standard Tesselated Geometry - 66.49 kB - 11/28/2020 at 03:53 |
Inner Shroud r0.STLPrototype inner shroud, now with the correct length! Use with "Lens Flange.STL".Standard Tesselated Geometry - 24.72 MB - 11/04/2018 at 08:57 |
SQ6_TLR_STL.zipAll of the 3D printed parts needed for the SQ6 TLR. This prints really well in Shapeways' black premium plastic.x-zip-compressed - 15.62 MB - 11/04/2018 at 08:04 |
eject_circuit_2.PNGSchematic for the prototype eject circuit.Portable Network Graphics (PNG) - 78.18 kB - 06/15/2018 at 04:38 |
instax_eject_h.kicad_pcbPrototype KiCad PCB file for the eject circuit. You can upload this to the OSHpark website if you want one. See Project Log #5 for the schematic.kicad_pcb - 39.66 kB - 06/15/2018 at 04:35 |
Inner Shroud.STLPrototype inner shroud. I'm having this printed at Shapeways. Might be possible using FDM, but some features are pretty small. This version is 2.08mm too long :(Standard Tesselated Geometry - 25.08 MB - 06/15/2018 at 04:35 |
Lens Flange.STLPrototype lens flange. I'm having this printed at Shapeways. You could make this using FDM.Standard Tesselated Geometry - 281.33 kB - 06/15/2018 at 04:34 |
