A few days ago I finished tests on my breadboard, being positive I decided to migrate my project to a pcb not only for functionality and practicality, but also for aesthetics, I have chosen the PCB manufacturer company Seeedstudio.com, we all know it as a manufacturer of hardware and IoT solutions , but they also have a PCB manufacturing service. I want to prove how my new ESP-LoRa / LoRaWAN prototype is. And making 10 prototypes is very simple and very economical for $5 USD.
Let's learn more about Seeedstudio
All at some time we have seen their wide variety of sensors, hardware, modules and their store, seeedstudio apart from being a manufacturer and distributor of IoT hardware, if you are a hardware manufacturer they would provide accompaniment as an ally in the integration of your project With IoT Platforms, its headquarters are located in Shenzhen, China and also has branches in the United States and Japan, they can easily distribute worldwide.
more info: seeedstudio.com/about
In this case we will not talk about your hardware platforms, we will use one of your services, our PCB Fabrication case for only $ 5 USD !!!! in Seeedstudio. also has other services that we will see later.
Other Services Available
Fusion Advanced PCB
This service allows us to manufacture our PCBs with many more specifications. Its main features are:
- More material options for pcb.
- Personalized stacking
- Better capacity in the manufacturing process.
- Mass production process.
- More info: Advanced PCB.
PCB Stencil
fabrication service "Stencil" is a template used to apply solder paste to the pad where SMD surface mount components will be placed.
- More info: PCB Stencil.
3D Printing
Seeed Studio has a 3D printing service, requires our .STL file, and certain manufacturing parameters are determined, I recommend to contact Seeedstudio. engineers beforehand.
More info: 3D print.
PCB Layout
They also have a complete PCB design service, basically it is upload schematic EDA design file or a schematic PDF and component listing file and configure other parameters, I recommend to contact Seeedstudio. engineers beforehand.
More info: PCB Layout.
Fusion Gallery
Seeed Studio has a community or space to share our designs and download other designs, there are several categories available.
More info: Fusion Gallery.
PCBA Seeed Fusión - PCB Assembly Service
This is the service that has caught my attention"Seeed Fusion One-Stop prototipo PCBA", this service of manufacturing and complete assembly, small lots of prototypes of high quality, affordable and reasonable prices, is perfect for engineering companies, manufacturers , Kickstarter projects and students, Perfect in case you want to make 100 prototypes will arrive ready to just connect and work, Manufacturing in 3 steps:
- Load gerber file "Design of our PCB".
- Load BOM format "Components"
- Instantly a full quote will be generated.
Scope of Prototype Testing
Seeedstudio has the required tests for the prototype from gpio's voltage I2C / Uart/SPI/CAN/Onewire SWD Temperature / Humidity / Atmospheric Pressure / Luminance to communications such as GSM/WCDMA/LTE GNSS Bluetooth/LE Ethernet NFC 802.11/b/g/n/a/ac among others, they are also in the capacity to generate certifications in their laboratories.
More info: Seeed Fusion One-Stop prototipo PCBA / PCB Assembly Service.
Abduulah Omran
ElectroBoy
mbsg99
