Hackaday.io Hackaday.io
Sign up Log in
Fix the Bike
A full overhaul of my motorcycle engine (and why I work so slow on my other projects)
edscalatieedscalatie
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
1 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
Public Chat
113
1
0
0
Team (1)
  • edscalatieedscalatie
Join this project's team
MISC
ongoing project
bike engine overhaul yamaha diversion Spark plug valves piston tinkering mechanic
This project was created on 05/29/2018 and last updated 8 years ago.
Description
I know this isn't really a hack or anything, but because it is a hobby and I'am tinkering away I will post some images and random stuff anyway. The logs on this project page will probaly explain why my other project(s) are taking longer. So here it goes I wanted to check the compression on my motorcycle engine. Because the spark plug broke off when trying to remove it, the project changed from a routine inspection to a full restoration. Logs images and updates will follow
Project Logs
Collapse
  • Disc grinders and dismantling
    edscalatie • 06/03/2018 at 11:26 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
j47089472 wrote 07/31/2023 at 13:18 • point
Backlinks: The quantity and caliber of backlinks pointing to your website are two of the most important criteria in off-page SEO. Backlinks are links that point users to your website from other websites. Websites with more authoritative backlinks are more likely to rank higher in search results because search engines view backlinks as a vote of confidence. https://techzone-agency.com/
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Fix the Bike", please tell us the reason.
Send message
Remove Member
