Krusty The It
A Terrifying Clown - TwinkleTwinkie's DC26 Shitty Add-on #1
Krusty the It is my first Shitty Add-on for DC26's various Indie Badges.
Currently Available on Tindie:
https://www.tindie.com/products/twinkletwinkie/twinkletwinkies-badgelife-sao-add-on-1/
Krusty_the_It_hackaday.zip
Completely raw KiCad Project & Gerbers
x-zip-compressed - 1.12 MB - 09/10/2018 at 13:08
Download
  • 1 × Krusty the It PCB
  • 2 × OSRAM TOPLED - LY T776-Q2T1-26-Z SMD LED that is designed to shine through the board.
  • 1 × 2x2 Vertical Headers / Shitty Add-on Connector Part #: M20-9980245
  • 1 × 51ohm 0805 SMD Resistor
  • Almost finished...
    TwinkleTwinkie05/30/2018 at 05:55 0 comments
    Today I finished soldering, testing, cleaning up, and bagging the Krusty Shitty Add-ons.  I'm now waiting on inserts and labels and after that they'll be complete and ready to go for DEF CON 26!
  • A Quick History
    TwinkleTwinkie05/29/2018 at 18:18 0 comments
    I am actually on my second revision of this board.  The initial revision had a place for a 0805 Resistor which turned out to be unnecessary.  Of the 140ish I'll be bringing to DEF CON approximately 45 will have a ZERO OHM Jumper where a resistor would have been.
    The second revision doesn't have this and I carried this knowledge over to my second shitty add-on.
View all 2 project logs
Andrew Green wrote 08/11/2020 at 08:08 point
Amazing.. it looks scary and fascinating at the same time.
Mike Szczys wrote 05/29/2018 at 17:24 point
Those teeth and eyes give it a very Pennywise vibe. This is my nightmare.
