Registers and ALU
A project log for BREDSAC
Electronic Dynamic Storage Breadboard Computer
gregewinggreg.ewing 06/17/2018 at 02:360 Comments
Register File
There will eventually be two of these, one holding the Accumulator and Multiplier Registers (which won't need to be accessed at the same time) and one holding the Product Register.
This subcircuit incorporates logic to support the division of each bit period into a Read and a Write phase. Data is read from the RAM when the clock is high and latched into the output flip-flop on the falling edge of the clock. Writing to the RAM is enabled when the WRITE control input is active and the clock is low.
ALU
The ALU is built around a one-bit full adder with a flip-flop to hold the carry between bits. Additional logic allows one of the inputs to be complemented (CMX = 1), and a logical AND operation to be selected instead of the adder output (AND = 1).
The CYP and CY1 inputs control the carry input to the adder during T0. When CYP = 0, the carry in is equal to CY1, otherwise the carry out from the previous cycle is used. During all other bit times, the carry out from the previous bit is used.
Useful combinations of control inputs include:
CYP CY1 CMX AND Result
0 0 0 0 Y + X
0 1 0 0 Y + X + 1
1 x 0 0 Y + X with carry in
0 1 1 0 Y - X
0 0 1 0 Y - X - 1
1 x 1 0 Y - X with carry in
x x x 1 Y AND X
Updated Main Circuit
Here's the main circuit with the ALU and one of the register files added.
The following microinstruction fields have also been added:
EOI End of Instruction Indicates the last short word cycle of an instruction. Causes LAST to be activated  during T17.
RFA1 Register File 1 Address Selects one of 8 short words in Register File 1.
WRF1 Write Register File 1 Causes the output of the ALU to be written into Register File 1.
XSEL X Select Selects the source for ALU input X.
YSEL Y Select Selects the source for ALU input Y.
CMX Complement X ALU control inputs
AND Logical AND
CY1 Carry in value
CYP Use previous carry
XSEL values:
00 Constant 0
01 Register File 1
10 Main Memory
11 Currently unused
YSEL values:
00 Constant 0
01 Register File 1
10 Currently unused
11
