Subtract
Microcode for the Subtract and Subtract Long instructions is very similar to the Add instructions, the only differences being the activation of CMX and CY1.
# OPCODE L STAT : FETCH MASEL SHS EOI RFA1 WRF1 XSEL YSEL CMX AND CY1 CYP ODD MSW LSW # S - Subtract 01100 0 0001 : 0 1 0 1 110 1 01 10 1 0 1 0 0 1 1 01100 1 0001 : 0 1 0 0 010 1 01 10 1 0 1 0 0 0 1 01100 1 0010 : 0 1 0 1 110 1 01 10 1 0 0 1 1 1 0
Halt
To facilitate running test programs of more than one or two instructions, it seemed like it would be helpful to implement the Halt instruction next. I added a HALT control signal that becomes a new input to the Run Control subcircuit. I also tidied up the Run Control logic a bit, renaming some of its inputs for consistency, and moving generation of the LAST signal from the main circuit into the Run Control subcircuit.
This is the new Run Control circuit:
This is how it fits into the main circuit:
Microcode for the Halt instruction is now straightforward.
# OPCODE L STAT : FETCH MASEL SHS EOI RFA1 WRF1 XSEL YSEL CMX AND CY1 CYP ODD MSW LSW HALT # Z - Halt 01101 0 0001 : 0 0 0 1 000 0 00 00 0 0 0 0 0 0 0 1
