• Servo Mount
    Tim Wilkinson06/03/2018 at 21:32 0 comments
    Below is the design for the servo mount which makes the knee of NaBi's legs.
    The six 3d printed parts wrap around a standard sized servo, and provides connection points for the upper and lower leg rods. The design also requires a bearing at the top to spread the weight and stress to both sides of the joint, not just the place where it attaches to the servo horn.
