Volt's Arm decided it preferred to be unattached on the way home from the Faire. This provided an opportunity to make that modular as well - we used a bird house clip from Amazon which did the trick. (Now we just need to figure out a way to remove his other arm without damaging it. ;) )
Volttherobot
