Building Process of Head Lamp
A project log for Body Heat Powered Flashlight
Infinity Flashlight Powered by Your Own Body Heat
wasim-sahuWasim Sahu 10/21/2018 at 13:310 Comments
For making body heat powered lamp first we need 4 aluminum blocks for heat sink propos. In 4 aluminum blocks we make at least 2 wholes. Then We will connect 4 blocks with hard wire passing by all 4 blocks wholes. First and last side of hard wire will fix two strips with this our headlamp will easily be hold on our forehead.
