This is a patch board for Shitty Add-on Connectors that were placed incorrectly on the board. It only provides Power and GND and has a place for 0805 resistor on the Power. If you do not need the resistor just bridge it.
You will need another 2x2 Header to use this board.
Pay close attention to the labels under "Add-on" if your pin configuration doesn't match this then DO NOT use this board! Feel free to fork and make variations to fix other scenarios.
2×
2x2 2 Row 2.54 Pitch Header
I use Harwin #M20-9980245. You need one for the badge and one for the add-on. If you already have the header on the add-on you only need it for the badge.
Got my boards back from Oshpark and tested it on a first run Fat Pika Reject and it works perfectly! I'm having 250 made and will bundle them with the other reject boards. I'll decide what to do with them after I get them in from China.
