Resurrecting a zombie MUM 5 (mum56z40) food mixer
My in-laws food mixer arced when plugged, running the motor even though the main switch was "Off". Some pcb milling and epoxy later, fixed.
1.9k views
0 followers
My in-laws food mixer was plugged in to mains power (turned off) and then suddenly started working. I'm guessing there was a small voltage spike on the power line which caused the arcing, but i have no evidence. The arc connected a live mains wire on the pcb with a relay, causing the engine to work.
First, see this log update - A zombie food mixer
Then, see this log update after the fix - It lives to fight another day!
You can see the problem and fix in the pictures of this project.
Lastly, as i didn't make a video of the device tear down, here's one my father-in-law found in russian - Repair of food processor BOSCH MUM5 ... replacement gear reducer - (no, we do not speak russian).
Visible arcing path, pcb bottom side.
JPEG Image - 3.67 MB - 06/07/2018 at 09:58
Preview
Download
More arcing damage, top (components) pcb side.
JPEG Image - 2.96 MB - 06/07/2018 at 09:57
Preview
Download
JPEG Image - 2.79 MB - 06/07/2018 at 09:57
Preview
Download
Dremel and 0.8 mm drill bits. I broke one while drilling, but could still use it broken.
JPEG Image - 2.72 MB - 06/07/2018 at 09:56
Preview
Download
Milled "air gap", bottom side of pcb.
JPEG Image - 3.83 MB - 06/07/2018 at 09:56
Preview
Download
View all 9 files
  • It lives to fight another day!
    CodeMonkey06/07/2018 at 09:52 0 comments
    There, fixed it. Milled out the burnt pcb area with a dremel and a tiny drill bit (0.8 mm). Made sure not to leave any black area on the pcb, basically creating an "air gap". Then filled it with epoxy.
  • A zombie food mixer
    CodeMonkey06/07/2018 at 09:50 0 comments
    This was the state of the mixer before fixing the pcb - a zombie. Not dead and unresponsive, yet seemed to have a life of its own:
    When plugged in the engine starts working, even though the main switch is in the "Off" position, you can see the arcing towards the end of the video.
View all 2 project logs
