It lives to fight another day!
A project log for Resurrecting a zombie MUM 5 (mum56z40) food mixer
My in-laws food mixer arced when plugged, running the motor even though the main switch was "Off". Some pcb milling and epoxy later, fixed.
codemonkeyhacksCodeMonkeyHacks 06/07/2018 at 09:520 Comments
There, fixed it. Milled out the burnt pcb area with a dremel and a tiny drill bit (0.8 mm). Made sure not to leave any black area on the pcb, basically creating an "air gap". Then filled it with epoxy.
