The TRXW is based on an SSB-Trx described by B.Kainka in the german ham radio magazine "CQ DL" in 1984 (see links), but modernized for the 21th century: The frequency generation is now done by a STM32F4 MCU, which can output up to 50 or 42MHz (in theory the TRX can work up to this frequency). Furthermore faster Logic ICs, low noise OPVs, better audio amplifier, and last but not least it mostly uses (0805) SMD parts...
The (designated) features are:
- SSB TRX for the most important ham radio short wave bands (160m up to (hopeful) 10m)
- LSB and USB (the modulation) support
- Display and rotary encoder for frequency input and menu
- Open Source hardware and software
- Cheap to build (<50$, maybe even <40$)
- 3D printable casing
- MCU can transmit and receive audio, so things like automatic stations are possible
- Controllable by PC via USB (now the Serial Bus)
