1Materials You Will Need:
1-NodeMCU ESP8266 board
1-PIR sensor
1-LM35 temperature sensor
6- 3904 NPN transistors
4-1n4001 diodes.
8-1k ohm resistors
4-5v relays
2-12v relays (can be replaced by 5v ones).
8-Terminal blocks
Some wiring to connect everything and that's it.
2Code and Schematic:
I attached the code and the schematics:
3Voice Control With Google Assistant Setup:
As you can noticed on this video i didn't use the same module model, but is the same way to program it and to set the ifttt account with the adafruit one.
4Assembly:
Be sure that the module is correctly connected, and the AC wiring, as i show you in the schematics.
5Testing It:
In the arduino serial monitor the module print the IP where it is connected, then write it up to your favorite navigator and enjoy the project.
Christopher Mendez
