ESP32 Home Energy Meter
Open source home energy meter based on the ESP32
The home energy meter will hook up to the electrical distribution panel in your home to monitor power usage for the entire panel and a few key branch circuits. The meter will wirelessly transmit real time metering data up to a Raspberry Pi over WiFi to store in a database. The Raspberry Pi will host a web server to present the data in a meaningful way to the user.
energy_monitor.pdf
Schematic
Adobe Portable Document Format - 121.60 kB - 06/09/2018 at 15:29
Preview
  • 6 × SCT-013-000 AC Current Sensor http://a.co/hBNF3AJ
Mauricio Vidal wrote 11/15/2018 at 05:18 point
Hi Jeff:
The isolation between the USB and the ESP32 looks neat.  Very clean!
Thank you for sharing your work.
