sponsored by aisler
A project log for Arduboy MAX
using a 2.42" OLED display and Game Boy buttons with a diy board around the atmega32u4
davedarkodavedarko 07/12/2018 at 16:003 Comments
They've contacted me via instagram - like oh so many pcb fab houses do these days - and offered a free run - couldn't say no! I've added test points to attach the RGB LED, not so keen on using it, but wanted to have the option. The display will be soldered via wires. There's no battery protection on it, only a charger. Extra pads for I2C. Additional test points for vcc and gnd. Buttons will be classic Game Boy pads.
ꝺeshipu wrote 07/12/2018 at 18:04 point
Wait, are you powering it directly from the battery without any voltage regulator?
davedarko wrote 07/12/2018 at 21:56 point
There's a regulator on it, but no level conversion - I think I can get away with it by adding 100R resistors in between the signals. It's all taken from the arduboy schematics, and now that you ask I feel a bit stupid not checking again o.O it's not to late to update at aisler.
Thanks for calling it out!
Richard Hogben wrote 07/12/2018 at 16:38 point
Nice!
