Solar Power Monitor Interconnections.pdf
This shows how the Solar Power monitor/inverter interface connects with the 8 way current monitor, the solar arrays and the MPPSolar PIP4048 inverter/charger
Adobe Portable Document Format - 437.92 kB - 07/15/2018 at 16:24
Preview
Download
ppip4048monitor.ino
Solar Power Monitor Arduino Files.
This uses the Arduino ATMEGA1284 library.
This version has pre-programmed MPPSOLAR and network values as the standard Arduino webservers don't work withe ATMEGA1284.
I am working on a full webserver for this to allow programmable parameters. This version needs the parameters to be set at the header of the program and then re-compiled
plain - 27.53 kB - 07/15/2018 at 15:54
Download
PIP4048 Monitor-W5500.BOM
Solar Power Monitor and interface to the MPPSolar PIP4048 offgrid inverter - parts list
bom - 14.30 kB - 07/15/2018 at 15:52
Download
Solar Power Monitor and interface to the MPPSolar PIP4048 offgrid inverter - schematic diagram
Portable Network Graphics (PNG) - 240.51 kB - 07/15/2018 at 15:52
Preview
Download
Solar Power Monitor and interface to the MPPSolar PIP4048 offgrid inverter - PCB Layout
Portable Network Graphics (PNG) - 118.67 kB - 07/15/2018 at 15:52
Preview
Download
8 Channel Solar Current Monitor.BOM
Component list for the 8 way solar current monitor
bom - 6.58 kB - 07/15/2018 at 15:50
Download
Shows the PCB layout and component placement of the 8 way current monitor
Portable Network Graphics (PNG) - 45.24 kB - 07/15/2018 at 15:45
Preview
Download
Schematic diagram of the 8 way current monitor.
Four of these boards can be cascaded to read up to 32 solar arrays
Portable Network Graphics (PNG) - 127.60 kB - 07/15/2018 at 15:44
Preview
Download
8 Channel Solar Current Monitor.zip
8 Way, 20A solar current monitor - interfaces to PCB Manufacturing files for the 8 way solar current monitor - just upload to your choice of PCB manufacturer.
x-zip-compressed - 133.12 kB - 07/15/2018 at 15:41
Download
PCB REF-PIP4048 Monitor V3.0.zip
PCB Manufacturing files - just upload to your choice of PCB manufacturer. This board reads the current and voltage from up to 32 solar panel arrays and send the values to an MQTT server
x-zip-compressed - 249.70 kB - 07/15/2018 at 15:37
Download
Elevation Bar.pdf
Elevation bar construction details
Also shows how to hang the solar panels
Adobe Portable Document Format - 1.90 kB - 07/15/2018 at 15:33
Preview
Download
solar_panel_tracker.ino
Arduino Code For the tracking controller. This use the Arduino ESP8266 Libraries
Additional Arduino libs are in the section at the start of the code file
plain - 90.51 kB - 07/15/2018 at 13:23
Download
Solar Panel Tracker Azimuth Bar.pdf
The Panel Rotator head construction details
Adobe Portable Document Format - 105.18 kB - 06/15/2018 at 14:13
Preview
Download
Solar Panel Tracker Ground Post.pdf
The solar tracker ground post
Adobe Portable Document Format - 54.71 kB - 06/15/2018 at 14:13
Preview
Download
ESP8266 Solar Panel Tracker BOM.txt
Solar Panel Tracker electronics main circuit board components list. All parts are easily available on Ebay or Aliexpress
plain - 6.83 kB - 06/14/2018 at 17:01
Download
Solar Tracker Battery Power Supply .txt
Solar battery charger and power supply component list. All parts are available on Ebay or Aliexpress
plain - 34.13 kB - 06/14/2018 at 17:01
Download
PCN REF-SOLAR TRACKER 2.3.zip
All production files for the solar tracker control PCB zipped up . Just upload to a PCB manufacturer
x-zip-compressed - 108.24 kB - 06/11/2018 at 09:50
Download
PCB REF-Lion Backup 2.3-.zip
All production files for the solar tracker power supply PCB zipped up . Just upload to a PCB manufacturer
x-zip-compressed - 144.56 kB - 06/11/2018 at 09:49
Download
Schematic for power supply - 5V, 12V and 6V which are backed up by an on-board Li-ion battery
Portable Network Graphics (PNG) - 102.60 kB - 06/11/2018 at 09:45
Preview
Download
Schematic for ESP8266 based solar tracker control unit. This has 3 PWM motor controls for linear actuators (only 2 used in this version)
Portable Network Graphics (PNG) - 101.69 kB - 06/11/2018 at 09:45
Preview
Download
PCB for ESP8266 based solar tracker control unit. This has 3 PWM motor controls for linear actuators (only 2 used in this version)
Portable Network Graphics (PNG) - 71.78 kB - 06/11/2018 at 09:45
Preview
Download
PCB for power Supply - 5V, 12V and 6V which are sbacked up by an on-board Li-ion battery
Portable Network Graphics (PNG) - 57.22 kB - 06/11/2018 at 09:45
Preview
Download
