Even More Prototyping
A project log for Project De Motu Imperium
This project aims to create a power generation system that uses motion to generate electricity.
garnet-koebelGarnet Koebel 06/16/2018 at 18:160 Comments
Uploaded some images of the test circuit I built. The rachet system is being redesigned and in later versions the generator will be able to generate power while moving in both directions. This design change involves swapping the ratchet system for a rack and pinion system that will rotate the generator clockwise even no matter which way the rack and pinion is moving.
