A project log for Alcosheep
Making roads safer
pierrePierre 06/14/2018 at 11:210 Comments
We researched programs to use the seven-segment display on arduino and the breathalyser, which took us quite some time since some codes were wrong, but we also had problems with the cable connections. Pierre had to redo the soldering since the connections didn’t correspond. Pierre Emmanuel and Emily searched for the codes and how to connect the breathalyser to the arduino as well.
 We also continued to work on the modelling of our box using solid works.
