New Panel
A project log for 16 step MIDI sequencer
Arduino based (ATMEGA 644) 16 step sequencer with 2 MIDI ports and direct drum triggers
RH ElectronicsRH Electronics 06/27/2018 at 20:230 Comments
Just got some new aluminium panels cut so this will fit in my new modular synth box, now it's 250x175 so more room to mount the components and circuit board.
The current panel is too small and left no room for a good fixing into a rack or case.
I need to give it it's own 5 volt regulator as the main PSU for the case is +/- 12 v only.
