Plate&CaseBuilderSettings2.JPGsettings specified in screenshot:cut polygon:circle:Top&Switch layer only 6mm diameter relative to [0,0] [x-72,-y+15];[x-53,-y+15];[x-34,-y+15];[x-15,-y+15] cut polygon:circle:all layers 3mm diameter relative to [0,0] [-x+15,-y-1.5]; [x-15,-y-1.5]; [-x+15,y+1.5]; [x-15,y+1.5];[0,y+1.5];[0,-y-1.5] add polygon:custom poly:all layers relative to [-x,-y]; [x-30,-y]; [x-30,y]; [-x,y];[-15,y];[-15,-y] clockwise points [0,0]; [5,-5]; [25,-5]; [30,0]; [25,5]; [5,5] JPEG Image - 90.22 kB - 06/18/2018 at 01:33 |
Plate&CaseBuilderSettings1.JPGsettings specified in screenshot:case type: sandwich usb cutout at -120 edge padding 5mm cherry only stabilizer switch type: mx _t:3 JPEG Image - 54.85 kB - 06/18/2018 at 01:33 |
Plate&CaseBuilderSettings3.JPGsettings specified in screenshot:Line Weight: 0.01mm JPEG Image - 24.83 kB - 06/18/2018 at 01:33 |
Sundial_KLE(AsUsedForPlateBuilderApp).txtThis was the KLE text used for the plate builder.plain - 7.01 kB - 06/18/2018 at 01:26 |
CNC_CUTOUTS_ALL_LAYERS.zipOutput from the keyboard plate builder tool at http://builder.swillkb.com/(Used raw KLE from http://www.keyboard-layout-editor.com/#/gists/2771f208f8110f4429eae55af6480313 as input. ) x-zip-compressed - 123.69 kB - 06/18/2018 at 01:19 |
PinMapping.pngMaps rows and columns to pins on the Teensy.Portable Network Graphics (PNG) - 22.63 kB - 06/18/2018 at 01:13 |
Wiring.pngWiring diagram, viewed from back of keyboardPortable Network Graphics (PNG) - 29.46 kB - 06/18/2018 at 01:13 |
sundial_firmware.zipSundial Firmware attached. These are output files from the web app hosted at https://kbfirmware.com/The ".hex" file is what gets flashed to the Teensy++ 2.0 You can upload the JSON file to their site and make changes to it and regenerate the other files from it. x-zip-compressed - 5.20 MB - 06/18/2018 at 00:58 |
