Parametric Blades
A project log for DIY Savonious Wind Turbine
A small wind energy harvesting system for charging batteries to power your projects when solar is not an option
laenLaen 07/13/2018 at 20:500 Comments
Since the limiting factor for the size of the blades is the size of your 3D printer's print bed, I designed this parametrically as well.
It supports these parameters:
As our savonious design requires three of these, I figured it would be smart to design it such that
