New Blade Design
A project log for DIY Savonious Wind Turbine
A small wind energy harvesting system for charging batteries to power your projects when solar is not an option
laenLaen 07/30/2018 at 04:090 Comments
Greg says Savonious blades work best when they can "spill" from one to the other through the axle, so I made a new blade design which allows the some overlap between the blades.  Another advantage of this is that it lets you print larger blades if you want.
The blades are self-symmetrical, and interchangeable.
Like before, they're parametric:
