Fusion 360
A project log for DIY Savonious Wind Turbine
A small wind energy harvesting system for charging batteries to power your projects when solar is not an option
laenLaen 08/01/2018 at 16:180 Comments
This has been the biggest project I've done yet with Fusion 360, and I've learned quite a lot.
I still have a bunch to learn.  When doing a design, do you put the nuts and bolts in, or is that too much detail? Should I be setting up joints?
Also, Fusion 360 has a really nice rendering engine:
