Making the first schematic
A project log for Flexible wearable power harvester
A miniature power harvester solar-based for wearables, IoT and my smart ring series
enriqueEnrique 07/10/2018 at 20:500 Comments
I have sketched a quick schematic about the general idea, but needs be polished and tested so shouldn't be taken as the final one.
There are some details:
-The CBYP should be a low leakage
-The CBYP should be placed close to VSTOR and GND
-The CSTOR should have a low ESR, and it's value is related to the cold start efficiency and time
-Is possible to add more solar cells on parallel or in series, but I prefer on parallel for not exceed the max input voltage.
-The inductor should have similar specs to one of the given in the datasheet
