Print update, :( 3 piece misprint
A project log for Phytoplankton Power ! - Hybrid Microbial Fuel Cell
Turn home wastes like food scraps into sustainable electricity production. Using Anaerobic Nitrifying bacteria, Photoplankton and the sun!
josh-starnesJosh Starnes 07/06/2018 at 16:552 Comments
Well a filament spool fell off the machine and hit the emergency stop button causing a misprint. Sad times.  So I started another print and finished out the last of what was on the white roll. I am out of white so I have switched to silver which is what I have the most of.  The second printer is working on 3 cells now and I believe will have enough for another 3 before the roll is too small to use for anything. Otherwise everything is going well. We have 10 cells printed, 13 once I pull the 3 off the printer when I get home.
Josh Starnes wrote 07/06/2018 at 17:19 point
I know right, when it stopped I was just praying that nothing was broken because there is not enough time in this challenge to be ordering 3d printer parts.
Jarrett wrote 07/06/2018 at 17:17 point
That filament spool has really good aim
