Case design & components placement
A project log for Productivity Timer (a.k.a. Pomodoro Timer)
For people who want to focus on certain task, the Productivity Timer is a simple device that divides your time into well-defined blocks.
lukeLuke 08/15/2018 at 12:250 Comments
As mentioned in previous log entry, I had to export 3D PCB model (with all major components), so that initial case design can be created. To do that, I used kicad StepUp plugin for FreeCAD. Exported STEP file was then loaded into Autodesk Inventor and I could start designing the case elements.
After a few hours of work, I had initial case design:
During the process I made small changes to components placement on PCB (like moving a switch a bit, etc.).
Now I could move on to PCB layout. I started with placement of all smaller components (like passives). The result is shown below (I'll take care of silkscreen later):
Next step is routing all the tracks :)
