Ok so the TEG module has been adhered using thermal adhesive. Then sealed up with 100 percent silicon all the way around. All that is left is to get a foam disc from hobby lobby. Paint green , cut the hole for the heatsink to drop through and the floating heat collector will be operational as intended!
