The last of the robot
A project log for The 2200 DVD archive robot
Where optical disks created from 1997-2010 were stored.
lion-mclionheadlion mclionhead 01/20/2020 at 06:320 Comments
The last of the robot was finally scavenged for parts & discarded to free up space.  Looking over the intricate mechanical wood work reminded the lion kingdom what a leap it was to go from a pure software programmer with no mechanical engineering or electronic skills to designing that, within a year.  The mechanical linkages moving DVDs around were a cut above the quad copters & rovers that came later because they weren't just static cargo carriers changing position.  They had to grab & replace objects & travel around large areas with mm accuracy.
