Blinky Ball (RGB)
An ever evolving LED project
A sphere of LEDs with PCBs as structure.
We are doing some crowd funding.
https://www.indiegogo.com/projects/blinky-ball-rgb-portable-led-sculpture-bluetooth#/
Help us buy thousands and thousands of LEDs.
In 2012 we did a Blinky Ball, it was 384 white LEDs with a 800mah battery and had a run time of a couple hours.  I was a great project, we tried to kickstart it but we came up short.  We ended building a dozen of them and they are still going strong.
About a year later, in late 2013, I started an RGB version.  Each slice had 24 common cathode RGB LEDs and three TLC59xx LED drivers.  There were a couple of problems with this... first it was very expensive.  At the time the TLC drivers were about 4 bucks in qty, so it would have cost ~$200/per ball for just that one part.  Also I couldn't find a RGB LED that looked good at low power, with 24 LEDs per slice, 3 junctions per LED at 20ma... its 1.4A per slice or ~22Amps for the whole ball, just for the LEDs.  So the project got shelved like so many other projects.
Four years later... 2017, my infant baby girl takes a shine to the original white Blinky Ball in my office.  And since my wife was making the baby clothes for her first birthday, I thought I would do what I do, and make something blinky for her.
So here we are, 6 years later revisiting the blinky ball.  The first prototype was huge and wired (no battery) after quite a bit of effort charliex got the software running all 1152 LED elements.  After a couple of false starts and a couple of melted wires we got it to look OK at 1 Amp and it looks great at 1.8 Amps (peak amp numbers).  Since that was well within the range of being battery powered, the next prototype had an 18650.  It runs for about 4 hours, it's smaller and my daughter loved it, even if it was a month after her birthday (It's OK she just turned one.)
That one was 20 LEDs per slice with 16 slices. We are going to make ver 3.0 with 24 LEDs per slice that should have a similar run time.  And since people complain that I never document anything... here we go.
20x16_RGB_Small_v2.1_Wifi.sch
sch - 958.87 kB - 06/27/2018 at 22:00
Download
20x16_RGB_Small_v2.1.sch
sch - 838.42 kB - 06/27/2018 at 22:00
Download
20x16_RGB_Small_v2.1_Boost.sch
sch - 549.18 kB - 06/27/2018 at 22:00
Download
20x16_RGB_Small_v2.1_Boost.brd
brd - 151.52 kB - 06/27/2018 at 22:00
Download
20x16_RGB_Small_v2.1_Speaker.sch
sch - 356.50 kB - 06/27/2018 at 22:00
Download
View all 8 files
  • 384 × 5mm PTH ws2812 LEDs
  • 1 × CYC4245 Cypress PSOC4
  • 1 × IRF9358 Dual P-Channel FET
  • 1 × ESP-WROOM-32
  • 1 × IP5209 Power SoC
View all 11 components
  • Weaponized Blinky Ball at Defcon 26
    mmca • 08/14/2018 at 22:23 • 0 comments
    Blinky Ball with TwinkleTwinkie's SAO 6
    Survived another Defcon!
    This year we brought along the Blinky Ball, for a little show and tell.
    While there, we installed the WiNX (Wi-Fi attack-defense) suite of tools on the ball (https://www.hackerarsenal.com/products/winx)
    We got a couple nibbles on the Deception setting, but we hope that was just people fooling around and not actually trying to connect to unknown random access point at Defcon.
    No one will probably ever install an Wifi scanner/sniffer, honey pot or a custom captive portal on their Blinky Ball.  But I am happy to report that if you want to, you can.
    We have also come up with an answer to, "What is that?"
    The answer we most often gave was, "It is something that sits on a desk or shelf and gives off light.... It's a lamp."
    • It's lamp that has 384 RGB light elements all individually addressable.
    • It's a lamp that has a 9 DoF IMU so it knows which way it is pointing, how fast it is accelerating and which direction is North.
    • It's a lamp that has a temperature sensor.
    • It's a lamp that has a gesture sensor so it knows which way you are flailing your hands.
    • It's a lamp that has a light senor so it can auto adjust brightness.
    • It's a lamp that has a color sensor so it knows the ambient color (you can also bounce back the Blinky Ball color to it self, to self calibrate.)
    • It's a lamp with a digital mic so it can react to sounds.
    • It's a lamp with a 32-bit DAC (and headphone jack) so you can stream music.
    • It's a lamp with a voice assistant (you need to supply a speaker and an Amazon account).
    • It's a lamp that has Wifi and Bluetooth so when you don't want to wave your hands at it you can use your phone or computer to control it.
    • It's a lamp that has a 4000mAh rechargeable lithium cell so it can do all of the above when it is away from its desk or shelf.
    In short, it is what happens when hackers design a lamp.
  • Comedy of Errors
    mmca • 07/27/2018 at 21:22 • 2 comments
    I got the boards back 2 weeks ago, but ran in to all sort of issues.  I decided to use a board house I hadn't used in a while and that caused some problems and there was also just some real crazy goofs on my part.
    I like to build new boards by hand, one section at a time to make sure everything works like it is supposed to, in this case that did not help too much.  Here are some of the fun mistakes I made on this board.
    I forgot to change the isolation in the GND pour and ended up with very tight clearances.  In this case 1.5A of 3v3 was right next to a small chip in the solder mask, a solder ball found it way to that gap it blew it out.  If I had had allowed a little more isolation in the GND plane, that area would have been clear and the chip in the solder mask would not have had any affect.  I fixed it with a little bit of nail polish, and this particular board is fine now.
    Here I isolated a little island of GND.  I don't even have a copy of the board file with this error, so I must have fixed it in the general course of tidying up the board.  Unfortunately it got sent to the board house, so the prototype has 15 little bits of Kynar wire.
    This one is just nuts.  The DAC IC was throwing a design rule check error (DRC), so in the course of trying to fix the problem I deleted the part in the schematic, rebuilt the part from scratch and put it back in the schematic.  There was still an DRC error and I went about looking for other possible solutions (turns out I had 'highspeed' checked).  But the problem was when I replaced the part in the schematic, I put it back rotated 180 degrees.  So when I built the board the 3v3 rail was pulled down to 3.24v... odd but not something I was really worried about until the DAC IC heated up to untouchable temps.
    Luckily the board is still usable if I rotate the IC on the board. (Note the pin one mark and the dot on the IC, fun.)
    This was also the first time I put a USB-Serial interface on the ball, up to now it has been an off board adapter.  When I was testing just a single slice, everything worked great.  Once the ball was completely built and I plugged in the ball to my computer, it blew the USB sub systems and reset my monitor (that was a little scary).  It seems my computer will let a device try to pull 2.6A from the USB port and then blow a fuse.  After a reboot, all was well with the computer.  As for the ball, it now has a button that can be pressed at boot to suppress the LEDs, so you can plug it in to your computer for programming.  Yay!  (If anyone out there knows of a USB hub that does 2.4A and data at the same time please let me know.)
    So that was a couple days of frustrating troubleshooting, but as you can see in the video above, it all works, so I'm pretty happy with that.
    If you happen to be at Defcon 26, drop by the Tamper Evident Village, I will have a blinky ball there for your viewing pleasure.
  • A small video break
    mmca • 06/27/2018 at 18:47 • 0 comments
    A small video intermission as we wait for PCBs to come back from board house.
  • Evolution of the Main Slice
    mmca • 06/27/2018 at 18:42 • 0 comments
    In our first Blinky Ball all 16 slices where the same PCB.  You would build out the main slice with MCU, Bluetooth, battery charger and the other slices just got LEDs and a driver chip.  I was super happy with this and was constantly patting myself on the back about it.
    But as we moved to the RGB ball and especially when we got to the battery powered RGB ball all the slices started to get specialized.
    This is the driver slice with Cypress PSOC4 and an logic level shift (the PSOC is a 3v3 device and the LEDs expect 5v signal).  In this version all the colors/patterns are done in PSOC4.  In the next version the heaving lifting will be offloaded to another processor.
    This is the power slice, It takes USB power and charges the 18650 and boosts the 3.7v of the battery up to 5v.  We are using the IP5209, a highly integrated power management SoC, it isn't the best documented chip, but we are figuring out all its little oddities.  It is a great little chip, you add a couple caps, resistors and an inductor... good to go.  Unfortunately there is no easy way to disconnect the 5V from the circuit, so the next revision has bits for that.
    Behind that mess of wires is the ESP32 slice.  We had the ESP8266 for some of the early protos but after using the EPS32 on the 2018 L1 badge, it made sense to switch.  This slice also has an i2s microphone and DAC.
    And here is the speaker slice.  That is a little speaker from a Lenovo monitor, they are available oinline from a factory buy out.
    What we wanted to do for the third revision was bring all the parts together back on to one slice.  Bringing it back to the original vision.
    This is what the main slice looks like now... ESP32, LED driver, mic, DAC and all the power bits.  It is off at manufacturing now, fingers crossed.
  • Connecting all the slices
    mmca • 06/27/2018 at 04:59 • 0 comments
    In the first Blinky Ball we used wires to move the power and signal around the ball between slices.  It was a little clunky and time consuming to build but seem to work OK.
    For the RGB ball we wanted something a little cleaner, more elegant.  So we combined the structure and the signal path.  The little slots that are soldered together to make the ball also carry the signals and power.
    The top cap pass the signal from slice to slice connecting the DOUT from one slice to the DIN of the next.  The bottom cap works in a similar manner but is just 5V and GND.
    Unfortunately there are still a couple wires in the build.  There are user buttons on the bottom cap and some sensors in the top cap that need to be wired.  The battery is connected to the power slice by wires and that slice is in turn connected to the power distribution cap (bottom).
    Still needs some cleaning up but its getting there.
  • Attaching LEDs to edge of PCBs
    mmca • 06/26/2018 at 21:55 • 0 comments
    On the earlier Blinky Ball with single color LEDs we just placed the holes near the edge and bent the LEDs over, it was easy and made for a very strong connection.
    When we moved to an common cathode RGB LED with four legs it got a little trickier.  It need to have four signals going to it, so I had this crazy notion of putting half the leads on one side of the PCB and the other two leads on the other side.
    This worked pretty well, its very strong and the LEDs line up directly on the middle of the PCB edge.  The main issue with this technique is that its a real pain to bend all the leads to fit on the PCB.  Each LED had to have its leads formed, then clipped to length.
    Next we moved to a WS2812 based addressable LED.  It still has 4 leads, but they get daisy chained together.  So in the current ball the PTH LEDs are just soldered in on their sides.
    At first I thought this would be an issue as the LEDs aren't centered on the PCB edge, but you really cant tell.  I also had concerns of the LEDs ripping off the pads, but it seems having 4 long pads is plenty strong.  (Yes, that's a speaker... more on that later.)
  • Recycling some LayerOne badges
    mmca • 06/26/2018 at 06:57 • 0 comments
    Our first blinky ball was monochromatic and run by an AVR driving some TLC5947s.  It worked very well but was a little expensive as each slice needed its own TLC IC.
    If we had done the same setup for the RGB ball it would have been 3 times the cost in driver ICs as each 5mm LED has three light emitting junctions.
    For the LayerOne 2015 conference badge (and again in 2016) we had a PSOC4 driving WS2812 LEDs.  (Fun fact, the circuit comes from charliex's Christmas lights in 2014... when we like a circuit we really milk it.) This was great as you can make a 'serial block' on the PSOC4 that drives the LEDs and you get an ARM core all in one package.
    Now if only you could mount the 5050 WS2812 LEDs on the edge of the PCB or if they made WS2812 LEDs in PTH that I could mount on the edge of the PCB.
    Well it turns out they do make WS2812 LEDs in a 5mm PTH.  I got a couple of those and soldered it on to a LayerOne badge, and Yay! it worked perfectly.  First little part of the puzzle solved.
    Next we need some power, the WS2812 LEDs need 5 volts the PSOC4 needs 3.3v and I want to use a 18650 Lithum Ion that runs a nominal 3.7v.  So what I would normally do is go through the TI catalog looking for a boost IC and a charger chip.  In fact that is what I did for the 2017 LayerOne badge.  It was a great power circuit, it let you charge the battery from USB and boosted the voltage to a nice steady 5V.  Unfortunately it cost about 10 bucks for just that little power section.  Charliex pointed out that what we needed was a battery bank and from there we tracked down some highly integrated power bank ICs that do boost/charge all in one chip.   So the Blinky Ball uses the same power section as the 2018 L1 Badge (same idea as the 2017 power section, with a less finicky power SoC).
    And speaking of the 2018 L1 badge, the blinky ball has the same ESP-WROOM-32 for bluetooth and wifi connectivity and a mic and speaker.... for reasons.
View all 7 project logs
  • 1
    V3.1 Build instructions
    I would like to apologize for the delay, I was crazy to think I would have time to work on the project over the holidays.  But the delay did allow us to include a programmer with the kit, so that's nice.
    We are going to assume you are familiar with basic soldering techniques, but will include some help for the more unique soldering challenges this build presents.
    Included in the kit is one slice marked with a pink B, we will use that to assist in the soldering of the LEDs.
    Place one of the sub slices on top of the 'B' slice, like so.
    Secure them together with a little bit of tape.
    Tin one of the pads for the LED.  I like to do one pad of each LED first, but you can do them one at a time.
    Add some flux and attach to pre-tinned pad.  Once it is secured, finish soldering the LED on.  There is a little 'D' next to each pad, to denote the direction of the LED.  The LEDs have a flat side and a round side.  If you are unsure, take a look at the populated main slice, the orientation is the same.
  • 2
    Testing the slice.
    Included in the kit is a slice tester.  It maybe white or black like the one in the pictures.
    Connect it to USB power using a micro-USB cable.  And connect to your completed slice like so:
    When connected and the TEST button is pressed, the signal will go from the tester to slice and the signal will return to the tester completing the circuit.  Both RGB LEDs on the tester should light up.
    If one of your LEDs on the slice does not light up and needs to be removed (either to be flipped or completely changed out.  I would recommend they be removed like so:
    Add a glob of solder that touch all four pins, heat of the glob and remove the LED.  Clean the pads, add a little flux and re-solder on the LED.
  • 3
    Programming Header PIns
    If you have a Cypress PSOC programmer, you will want to solder the programming pins in with a little extra clearance.
    If you intend to just use the programmer supplied, you can just leave enough clearance for a jumper wire.
View all 6 instructions
Eric Migicovsky wrote 08/09/2018 at 04:47 • point
Could you upload the brd and sch for the top/bottom connector boards? We're looking to get some of these fabbed for burning man :)
B1tl0rd wrote 07/12/2018 at 13:06 • point
could you upload the source code?
and if it is not available, you can buy the complete kit
Thank you.
mmca wrote 07/12/2018 at 17:28 • point
Nothing finalized yet. Still waiting on next run of prototype PCBs
mpinner wrote 06/27/2018 at 21:03 • point
any extra boards? i'd love to try this latest
mmca wrote 06/27/2018 at 21:59 • point
Hey!
No extras as I've been ordering just enough to build out two at a time (about 40 PCBs each time).  But I think this next revision is going to get kitted up.  Will definitely let you know.
mpinner built one of our original blinky balls, one of only 12 that ever got made.
Kurt Van Kelst wrote 07/06/2018 at 17:21 • point
13........i made one too
Kurt Van Kelst wrote 06/27/2018 at 18:58 • point
no schematics?   files
mmca wrote 06/27/2018 at 19:02 • point
Our hackerspace's svn server had a massive break down a little while ago.  All files will be moved to a more robust solution soon.
Mike Szczys wrote 06/26/2018 at 17:43 • point
I would recognize this blinky ball anywhere! I loved the earlier version and am glad to see you're continuing to riff on this. It looks fantastic!
mmca wrote 06/27/2018 at 05:08 • point
Hey Mike,
Yup, it all started because of that LED ball post on Hackaday all those years ago.
