In the previously post I described an simplified version of the scanning array with only two sensors.
This is, what the signals would look like if there was a single object.
Well, what's next? With these time-discrete readings of ultrasonic amplitude we can do something simillar to a time-discrete convolution to create a 2D image.
The white dot marks the object. In this simulation there is only one object, if there were more than one, artefacts will appear.
To eliminate the artefacts, a threshold is applied.
%input data simulation: clear size = 10; f=ones(1,size); g=ones(1,size); style='rx'; f(2)=3; f(5)=4; g(4)=3; g(6)=4; threshold = 4; %plot input data subplot(2,1,1) stem(f,style) subplot(2,1,2) stem(g,style) %create heatmap z = zeros(size, size); for r = 1:size for c = 1:size z(r,c) = f(r)*g(c)-threshold; end end z(z<0)=0; %plot heatmap fig = figure; colormap('ocean'); imagesc(z); %create plot colorbar; %intensity bar
