I am creating this entry in order to show you how all different stages are being merged into a main system, the eBox. The eBox is the brain of the bike, a box that gathers, process and stores all data. It also has the ability to process commands from sensors, like a car ECU (lets call it bECU)!
Hence, let me start with the diagram of the system:
Please bear in mind that this schematic may change (a lot) as I am currently creating a Prototyping Board with all modules embedded.
I would like to clarify a few things before going mad:
- D stands for 'Diode' and I will show their specifications asap.
- R stands for 'Resistor'. R1 is 1KOhm, R2-R4 are 220Ohm and R5 is 10KOhm.
- C stands for 'Capacitor'. C2 is needed to smooth power surges if any (I may remove it).
- FL stands for 'Front Light'
- RL stands for 'Rear Light'
- RI stands for 'Right Indicator'
- LI stands for 'Left Indicator'
- B stands for 'Brake'
- MS stands for 'Main Switch'
Q&A Section
How many controllers are being used on this project?
At the moment only one. However, I could appreciate some lag when testing the light system. I will merge all the code and see how it goes but I believe one MCU will be for data logging an another one for the system management.
Why a diode in the Vin pin?
From previous experiences I have observed that Vin also provides 5V. This will avoid any possible issue.
A box in a bike like in the pictures?
Well, yes and no. I need a waterproof container to install all the electronics. This eBox needs to be compact, modular, small and also needs to use a common fixation point that all bikes have. The bottle cage mounting point is my first choice.
I know, it is still a box but I have some nice designs in mind, and you should be able to still use the mounting point for its original purpose.
UPDATE - 6/10/18
I have made lots of changes regarding the electronics and I would like to explain all of them in a new log entry as I am leaving this one for reference. It is always nice to see a 'before' and 'after' picture.
Please, find the new and updated log entry here: eBox Stage 2.0
Javier Betancor
