mWessenger_v3.brdEagle files - boardbrd - 92.20 kB - 10/22/2018 at 07:29 |
mWessenger_v3.schEagle files - schematicssch - 239.16 kB - 10/22/2018 at 07:29 |
mWessenger_v3_3Dmodel.step3D model of PCBA, just in case you want to use it with other PCBs / make custom casestep - 964.58 kB - 10/22/2018 at 07:29 |
mWessenger_v3_Gerbers.rararchive with Gerber files in RS274X format.RAR Archive - 391.97 kB - 10/22/2018 at 07:29 |
mWessenger_v3_BOM.odsBill of materialsspreadsheet - 13.18 kB - 10/22/2018 at 07:29 |
mWessenger_v3_Document.pdfPCB overview document, which can be used also as assembly manual for component placing on PCBAdobe Portable Document Format - 112.00 kB - 10/22/2018 at 07:29 |
mWessenger_v3_Schematics.pdfSchematics of final version of project in PDF formatAdobe Portable Document Format - 26.87 kB - 10/22/2018 at 07:29 |
mWessenger_Harvester_Analog.rarThe next prototype files - energy harvester PCBA, based on ADP5091. There is also BGM111 BLE module foreseen on that board.RAR Archive - 1.06 MB - 10/22/2018 at 07:27 |
mWessenger_Detector_n_Harvester_LTC.rarthe first prototype's files - there is voltage detector PCBA and energy harvester, based on LTC3108 IC.RAR Archive - 846.86 kB - 10/22/2018 at 07:24 |
voltage_stager_LED.ascThe simulation for circuit, which turn's on FET, after certain voltage level is reached at it's input. Threshold votlage setting is done using LED.asc - 3.83 kB - 10/07/2018 at 13:57 |
voltage_stager_TVS.ascThe simulation for circuit, which turn's on FET, after certain voltage level is reached at it's input.Threshold votlage setting is done using TVS diode.asc - 3.69 kB - 10/07/2018 at 13:57 |
