HF Differential Probe
High Frequency Differential Probe, DC-100MHz, +/-15V
This project is an isolated high frequency differential probe ideal for monitoring signals such as RS-485, CAN, MIL-STD-1553 and so on. It is DC coupled, and can also be used for differential DC voltage measurements such as Vbe on a transistor. The floating battery supply eliminates the possibility of ground loops.
evermore99 wrote 03/20/2021 at 23:22 point
did you base the circuit on the one proposed from linear technology? https://www.analog.com/en/products/ltc6268-10.html#cc-overview
