Flipdot prototype BOM
A project log for Flip-Dot Display & DIY Controller
Messing around with Annax Flip-Dot displays.
frederic-lFrederic L 08/11/2018 at 07:180 Comments
With the PCB on their way and expected to arrive next week, it was time to order the components required for the assembly. Here is a table with the references used, quantity and unit price (for ONE display).
DescriptionReferenceQuan-tityUnit PriceTotal Price
Shift RegisterSN74HC595N120,374 €4,488 €
Source DriverMIC2981/82YN61,74 €10,44 €
Sink DriverULN2803A60,867 €5,202 €
10k ResistorsMFR-25FBF52-10K480,017 €0,816 €
0.1uF CapacitorK104K15X7RF53L2140,039 €0,546 €
IC Sockets for Drivers1-2199298-5120,179 €2,148 €
40 pos. flat cable (1 ft)3365/40-CUT-LENGTH11,39 €1,39 €
40 pos. Board Connector5103308-821,99 €3,98 €
40 pos. Cable Header1658621-941,30 €5,2 €
40 pos. Header Strain Relief499252-140,241 €0,964 €
18 pos. Cable Header (for daisy chaining)71600-318LF21,41 €2,82 €
NAND GateSN74HC00N10,408 €0,408 €
Bistable LatchCD74HC75E10,757 €0,757 €
9x2 Pin Strip (for daisy chaining)67997-218HLF20,587 €1,174 €
24V Power SupplyLRS-100-24115,91 €15,91 €
TOTAL56,25€
A total of 40 € of components (excluding the power supply), for 1 display, so 80€ in my case as I want to try daisy chaining both displays together. A bit pricey for a prototype but some components will be re-usable, such as the drivers (mounted on sockets), and cable assemblies.
