Voice Kitchen Faucet
de Bergerac The Dishes
Touching is far too forward when first getting to know your kitchen faucet.
You must first serenade it ..
.. here then is the Cyrano de Bergerac method of dish washing.
Notations
1. Limited positions to averaging hot/cold/mix in deux bcz .. less is more.
Would diversify per #3.
2. #MakeArduinoCheapAgain
3. Recommend https://github.com/netlabtoolkit/VarSpeedServo as alternative to littering annoying for-statements .. unfortunately avr/interrupt.h is not ESP8266 compatible.
4. Shameless plug for https://www.theio.nyc/
5. Will you ever learn, me?! Shd you believe the arms are long enough .. add more.
6. FYI .. Jacob is my personal AI. Say no to Amaoogpple!
Archive
https://hackaday.io/project/159473-voice-kitchen-faucet
http://vijemiller.com/index.php?entry=entry180829-231919
https://www.thingiverse.com/thing:3074690
Alternative Suggestion for Voice Commands: https://voiceattack.com/
Per Steven Dufresne's healthy skepticism .. https://hackaday.com/2018/09/01/talk-to-the-faucet/ .. a 3+ year old cheese-laden introduction to Jacob:
SSEYO Koan Play File - 1.60 MB - 08/30/2018 at 04:33
Download
SSEYO Koan Play File - 1.60 MB - 08/29/2018 at 22:49
Download
SSEYO Koan Play File - 1.84 MB - 08/29/2018 at 22:49
Download
  • 1 × NodeMCU ESP8266 ESP-12E V2
  • 2 × Micro Servo 9G
  • 1 × 5V Power Supply
  • 1 × Jacob AI (Proprietary)
  • 1 × PLA
  • Code (Version 0.1)
    Vije Miller08/29/2018 at 22:49 0 comments
    This is the bare bones version .. as opposed to a more elegant version one may make with map() the positions and a variable speed servo script
    Relative to your voice command system .. simply have a series of keyword commands like 'kitchen' and 'hot' etc to load the NodeMCU ip address and add /hot=50 et cetera ..
    // Voice Kitchen Faucet V.0.1 (NodeMCU)
    // Vije Miller
    #include <ESP8266WiFi.h>
    #include <Servo.h>
    const char* ssid = "ssid";
    const char* pass = "password";
    WiFiServer server(80);
    Servo left;
    Servo right;
    // Servo Pins
    const int ser_l = D6;
    const int ser_r = D5;
    // Version 2.0 would map() distance
    // between off and peak temp ..
    // Off
    int l_off = 60;
    int r_off = 110;
    // Hot
    int hfl = 70;
    int hfr = 50;
    int hol = 60;
    int hor = 10;
    // Mix
    int mfl = 90;
    int mfr = 75;
    int mol = 130;
    int mor = 35;
    // Cold
    int cfl = 110;
    int cfr = 90;
    int col = 160;
    int cor = 90;
    // Position
    int pl = 70;
    int pr = 90;
    // LED
    int led = D0;
    void setup() {
      Serial.begin(115200);
      pinMode(led, OUTPUT);
      digitalWrite(led, LOW);
      left.attach(ser_l);
      right.attach(ser_r);
      left.write(l_off);
      right.write(r_off);
      // Connect
      Serial.println(ssid);
      WiFi.begin(ssid, pass);
      while (WiFi.status() != WL_CONNECTED) {
        delay(500);
        Serial.print(".");
      Serial.println("Connected");
      server.begin();
      Serial.print("http://");
      Serial.print(WiFi.localIP());
      Serial.println("/");
    void loop() {
      // Check
      WiFiClient client = server.available();
      if (!client) {
        return;
      // Wait
      while (!client.available()) {
        delay(1);
      // Read
      String query = client.readStringUntil('\r');
      client.flush();
      if (query.indexOf("/hot=50") != -1)  {
        hot(50);
      if (query.indexOf("/hot=100") != -1)  {
        hot(100);
      if (query.indexOf("/cold=50") != -1)  {
        cold(50);
      if (query.indexOf("/cold=100") != -1)  {
        cold(100);
      if (query.indexOf("/mix=50") != -1)  {
        mix(50);
      if (query.indexOf("/mix=100") != -1)  {
        mix(100);
      if (query.indexOf("/off") != -1)  {
        off();
      delay(1);
    void off() {
      left.write(l_off);
      right.write(r_off);
      delay(5);
    void hot(int q) {
      if (q == 50) {
        pl = hfl;
        pr = hfr;
      } else if (q == 100) {
        pl = hol;
        pr = hor;
      left.write(pl);
      right.write(pr);
      delay(5);
    void mix(int q) {
      if (q == 50) {
        pl = mfl;
        pr = mfr;
        pl = mol;
        pr = mor;
      left.write(pl);
      right.write(pr);
      delay(5);
    void cold(int q) {
      if (q == 50) {
        pl = cfl;
        pr = cfr;
        pl = col;
        pr = cor;
      left.write(pl);
      right.write(pr);
      delay(5);
  • Simon
    Vije Miller08/29/2018 at 04:38 0 comments
    Seeing as female jumpers seem all but non-existent now .. while boards still offer male leads .. permits me a moment of cursing loudly while soldering.
  • Michael J. Fox Setting
    Vije Miller08/27/2018 at 02:57 0 comments
  • CNC to 3D to BM
    Vije Miller08/23/2018 at 18:48 0 comments
    CNC'd cardboard out of sheer elation having a CNC again .. and while it worked well .. 3D printing this project seems more appropriate. 100's of other projects I can cut alternatively so .. meh.
  • Craftsmenshipiness
    Vije Miller07/11/2018 at 04:32 0 comments
View all 5 project logs
Romain LAPIERRE wrote 09/03/2018 at 00:38 point
That's just awesome! Gonna try this out soon :p
Vije Miller wrote 09/03/2018 at 01:03 point
Keep me posted on how it goes ..
Josh Starnes wrote 09/01/2018 at 23:13 point
you need to paint it and give him a face with some googly eyes
.. then a Millennial attitude so it only gives me water when I am either nice and/or when it feels like it.
Alexander wrote 08/30/2018 at 05:08 point
Brilliant invention as always! Now I don't even want to see my outdated faucet anymore.
Vije Miller wrote 09/03/2018 at 01:04 point
Pft .. just look at those handles just sitting there all not moving on their own .. pft .. so archaic. I need to add the entire sink to a movable robot so I don't even have to leave the couch to wash my dishes.
