Heat Sink Update
A project log for SEBS (Seebeck Effect Buoy System)
This Buoy, with peltier modules attached, will use the Seebeck Effect to generate electricity using the ocean and the sun.
kedricKedric 07/15/2018 at 02:150 Comments
To make the temperature between the foil plates and the peltier modules transfer more efficiently I added a thin layer of Arctic silver thermal paste in between.
