Water Proofing
A project log for SEBS (Seebeck Effect Buoy System)
This Buoy, with peltier modules attached, will use the Seebeck Effect to generate electricity using the ocean and the sun.
kedricKedric 07/15/2018 at 02:280 Comments
To prevent water from accidentally being splashed onto the circuitry at the top I hot glued a clear cylinder covering from an old tape container to the top of the buoy. For the side of the covering that is facing the USB opening of the Boost Converter I cut a snug fit hole and in the process of trying to find some material to fill in the sounding to keep water from leaking in.
