Initial Concept
A project log for 8-Bit Reviver
An Arduino Mega2560 with DIP28 adapter to emulate 27C series eeprom up to 64KB.
bart-van-der-weeBart van der Wee 07/02/2014 at 02:510 Comments
My first thought was to have the Mega directly connected to the eeprom address/data/control lines. When it received an address it would then lookup the corresponding data byte in it's own flash memory and put it on the data bus.
A closer look at the timing charts for both chips shows that this approach will be too slow even with highly optimised AVR assembly language routines - which I wasn't going to attempt I had hope to do everything from within the Arduino IDE!
