Test Fitting the lid and salt bridge.
A project log for P CEll ! Urea Electrical Power Harvesting Device
Pee Power!! , Seriously you can charge your phone, tablet and laptop from pee!. It is avail anywhere animals or humans are.
josh-starnesJosh Starnes • 07/11/2018 at 21:11•0 Comments
the lids are almost perfect, but I did widen the holes so that the parts will slide in without too much force. the parts will be adhered together once put together.
The Salt bridge fits but is snug at this time. A little cleanup with dremel and sanding drum should clean it up.
