Pretty minor pre-flight check misses were found and fixed:
- Crazy track found near motor MOSFET was found and removed.
- Copper fill has been refreshed.
- The component list has been updated.
- Wrong component value for current-limiting resistor has been fixed.
- Affected components:
- R6 and R7, 47R and 10R respectively
- To reduce the brightness, increase the value of R6 to 100R
- The component list has been updated to reflect on the changes.
- Speck of incorrectly placed track near the edge of the board has been removed.
- A wrong value was used for R6. It has been fixed. (45R -> 82R) If that value were to be used, the current would be 28mA instead of desired 15mA.
- The single SIP switch has been changed to more readily accessible MSK-12C02 clone switch. (Credits: mzst)
- The position of the switch has been moved to more accessible area.
- A little bit of pizzazz was added.
- The board layout has been changed.
- The snake-through track has been rerouted.
- The little break-off tabs are now thicker to prevent it from falling off during manufacturing.
- Board version has been updated.
- Now the archive also includes firmware.
- Firmware issue (watchdog timer issue) has been fixed, perhaps by an overkill solution.
JLCPCB has contacted me about this board and I'm gonna have it manufactured. Time to go shopping for the components!
Update: Shopping is done. Now we wait...
