Ver 1. Trimming to fit
A project log for Cyborg 360 Flir AR HUD Motorcycle Helmet
Worlds Largest 7" Diagnal personal AR display in a motorcycle helmet, see 360 degree view, smart interface. Flir, IR and Ultrasonic
josh-starnesJosh Starnes 07/30/2018 at 05:050 Comments
so one of the many challenges is to get the Gear VR goggle casing to fit into the helmet opening and still align on a humans face. Me being that human. I took the helmet completely apart to see what I could ditch. I removed the drop down tinted visor as that will no longer be needed. It took several adjustments, but after careful trimming the Gear VR case will fit into this area. Next I need to extend the body at least an inch to accommodate a outside cover , the hud parts and the screen parts as well.
