The form factor of this laptops motherboard is very rectangular with all the ports conveniently on one side. This should make it easy to design a viable enclosure.
Links to in progress Fusion 360 files will be listed in the links section.
Some thoughts:
- This will probably become an OctoPrint server
- Should I replace the cooling?
- A copper plate with a large heatsink would probably work really well
- But the OEM heatsink and fan are really compact
- Powering any other fan from the motherboard might be a problem
Leo Covarrubias
I have not tried to test if the wifi works yet, working on the test bench sled files in Fusion 360 currently. I will probably switch to Linux Mint instead of pure Debian for ease of use.
Wifi was not working, but connected to the network with ethernet cable just fine and was able to ssh into the machine.
Neil Lambeth
txdo.msk
zapwizard
On the off chance that you interface all screens, stockpiling gadgets, and different peripherals to a dock, you can just associate your Macbook pro to a center or docking station when you return home, and presto: work area!
https://pcsforsaleonline.com/
