Version 2
A project log for Macbook to mini-desktop conversion
I'm converting an old 2009 macbook pro to a mini linux desktop.
Leo CovarrubiasLeo Covarrubias 07/08/2018 at 04:320 Comments
I updated the motherboard sled and printed a carriage for the ssd.  They nest together nicely but I need to work on cable routine.  Also I'm using nylon screws which is a bad idea.  I had to cut the wifi antenna a little bit to be able to access the screw holes from the top.
