The Problem:
There are an estimated 150 million metric tons of plastic trash in the ocean, with an estimated 8 million added each year. 7.764 million out of the 8 million tons added annually are macroplastics. Plastic pollution like water bottles, plastic bags, and styrofoam from coastlines face no barriers getting out to deep sea, where they break down into microplastics, becoming more difficult to clean up. These microplastics negatively affect marine biodiversity and ultimately, all life on the planet.
The technical capabilities to create some solutions to marine plastic pollution mostly exist, but resources - time and money - haven’t yet been invested in engineering projects dealing with this issue. NOAA estimated in 2015 that cleaning up less than 1% of the north Pacific Ocean would cost between “$122 million and $489 million for the year” using large boats with nets for the cleanup. Also, existing solutions to prevent plastics from reaching deep sea have no means to distinguish between plastics and marine life, further endangering those species (yikes!).
The Solution:
We're building F.L.O.A.T.I.B.O.I. (Floating Long-term Oceanic Autonomous Trawler Incorporating Buoyant Object Identification) - a method to actively prevent plastic from going out to sea by collecting it in nearshore waters while it is still mostly intact. F.L.O.A.T.I.B.O.I will harness renewable energy to keep its carbon footprint low, and artificial intelligence to aid with object identification. Addressing the high overhead and operational costs by creating a much lower-cost solution focusing on prevention rather than cleanup will allow us to make more progress towards stopping plastic from entering our oceans in the first place.
Sanjana Paul
Glytch
Md. Moniruzzaman
Wil Carver
Vittorio Loschiavo
Sounds like a cool project! I was wondering about your wind/water turbulence turbine idea with the 180 degree flip. I'm not sure a design like that would work underwater as the boat would move with the waters motion, it would need something to push against. However! something I have wanted to do for a while is use an underwater hydrofoil to use wave energy for passive propulsion. Sorry if you've already mentioned this, I read through it quite quickly.
https://www.youtube.com/watch?v=UWpxtfmpVD4
